Torque Convertor Question?
Old May 28, 2015 | 05:11 PM
OffroadFrance's Avatar
Re-try refilling the autobox with ATF with the engine running and manipulating the gears. If this doesn't work hook up a diagnostic tool to the OBD2 port and check whether the gears and xyz switch is functioning OK which will read wxyz on the diag tool. IMO, my guess is the autobox oil pump is NOT being driven OK by the torque converter athough you left the TQ in place when removing and replacing the engine. It is possible to check the autobox for oil circulation and pressure I believe.
Old May 29, 2015 | 10:13 AM
acamato's Avatar
From the RAVE:
9. Fill gearbox with recommended oil to bottom of oil level/filler plug hole.
10. Select 'P' (Park).
11. Ensure handbrake is applied.
12. Start engine and allow it to idle.
13. Apply footbrake.
14. Move selector lever through all gear positions, while continuing to fill the gearbox. Select 'P' (Park).
15. With engine idling, continue filling gearbox until a 2 mm bead of oil runs from oil filler/level plug hole.
16. Fit new sealing washer to automatic gearbox filler/level plug, fit plug and tighten to 30 Nm (22 lbf.ft).
17. Stop engine.
18. Remove all traces of oil from gearbox casing.
gbob
Aug 24, 2016 08:40 PM
Discolife
Jun 14, 2012 02:16 PM
Scott R
Feb 13, 2010 12:09 AM
03discoman
Dec 28, 2009 01:09 AM
barnesy1977
Mar 11, 2009 07:21 PM
