Touchscreen Radio in Disco 2 with HK Stereo
Old Jan 23, 2023 | 02:49 PM
YETIX's Avatar
Default Touchscreen Radio in Disco 2 with HK Stereo
I promise I have done a ton of research and cannot find an answer. Has anyone installed a touchscreen head unit in a Discovery 2 with the Harmon Kardon stereo which is NOT one if those swivel stereos (where the face plate is attached with a swivel)? If so, which stereo did you use?
If you did use a swivel stereo, which one did you use and how do you like it? Any pictures?
This is what I mean by a swivel stereo:
Thank you very much in advance@@
Old Jan 23, 2023 | 03:18 PM
Discorama's Avatar
It need a head unit with balanced outputs because the HK power amp has balanced inputs. Otherwise you get issues with noise.
Old Jan 24, 2023 | 08:23 AM
mollusc's Avatar
Pretty sure the 1.5 DIN Joying unit I have in mine is well documented in the https://landroverforums.com/forum/au...lectronics-10/ forum. Along with several others.
Old Jan 24, 2023 | 09:26 AM
Disco-2-V8-NL's Avatar
i’ve a pioneer sph evo64 radio. Works fine with steering wheel control and the hk amp.
Old Jan 24, 2023 | 03:31 PM
YETIX's Avatar
Thanks for the ideas guys. Anyone else?
Old Jan 24, 2023 | 09:34 PM
mln01's Avatar
Uh, yeah. A unit that never works, according to the YouTube video? Explain?
Old Jan 25, 2023 | 04:50 AM
The radio died, but got replaced under warrenty. I had no photo, so thought sharing a video how it looks would be nice
Old Jan 25, 2023 | 09:51 AM
mln01's Avatar
Ah. Got it.
Old Jan 25, 2023 | 01:45 PM
OCMike's Avatar
https://youtu.be/yx6wquibEWc
That lengthy boot up would drive me insane!
Old Jan 25, 2023 | 09:22 PM
SundayFunday's Avatar
I’ve installed & use a pioneer NEX head unit, which is touch screen with Apple car play & mirroring.. it is not a swivel unit. The truck is has the HArmon Kardon system
Are you looking for a non modifying dash unit?
