towing with 01 Disco
Old Mar 19, 2013 | 01:17 AM
01LandRvrDiscoII's Avatar
8th Gear
Default towing with 01 Disco
hi guys,
what is the recomended towing weight for my disco?, i know the max is 7700 but that's in low gear.
Old Mar 19, 2013 | 01:43 AM
see attached chart from owners manual, which is part of the free RAVE download.
1650 if no trailer brakes. 4400 - 5500 depending on passengers and gear.
File Type: pdf
Old Mar 19, 2013 | 06:49 AM
iambhooper's Avatar
I always find the interpretation the difficult part. I know I should know better, but can someone actually put this in terms that count? Isn't Gross Vehicle Weight not the total weight of the Rover/passengers/object towing? When your starting with a 4400 truck, throw in 2 people and gear (500 lbs) your at 4900 before adding a trailer. I have a Kaufman 24' steal flatbed trailer... I bet that thing weigh's close to 2000 lbs easy, so now I'm at 6900 before even putting a car on the trailer (as I interpret it). Add a 2200 lb Miata to that trailer, and now I'm looking at a total weight of 9100 lbs.
Am I calculating this wrong?
Old Mar 19, 2013 | 07:30 AM
If the trailer has brakes, then you look at that as sorta a separate vehicle.
The owner manual says you can safely (if well skilled) use a trailer with brakes that is 5500 pounds, but you can only add 450 pounds to the truck (that would be one of me plus a slender blonde and small picnic basket). What you can't do is tow 5500 pounds, with a roof rack full of gear and five big guys inside plus six tool boxes.
This doesn't mean you can't move the trailer, but it sets a point at which the lawyers and insurance companies may remove what is left of your fortune after an accident.
Old Mar 19, 2013 | 07:58 AM
iambhooper's Avatar
Interesting, so that's exclusive of the actual truck weight. Which means, in theory, I could use a D2 to tow my SM to the track... as long as I don't carry spares.
Old Mar 19, 2013 | 10:04 AM
Ghaniba's Avatar
If the trailer has brakes, and you're setup to have them actually work on the rover -- I wouldn't hesitate to pull a little Miata on the back with any car trailer that would fit on a normal tow ball. As with any towing - take it easy.
Dave
GeoC
Jul 17, 2008 07:19 PM
dirtymorgan
May 7, 2008 08:10 PM
mc_eyes
Apr 29, 2008 05:27 PM
boyofcows2
Feb 18, 2007 04:16 PM
Benhamtroll
Jul 22, 2005 12:31 AM
