Towing and shift points
Old May 10, 2017 | 08:49 AM
film842's Avatar
Default Towing and shift points
Picked up my new travel trailer last weekend and found out that I can barely stay in high gear at highway speeds. (2002 disco pulling a 3000 lb trailer) In other words, if there's a bit of incline or some wind, it can't hold high gear at 2000 RPM/55 mph and will kick down to the next gear and run at around 2400 rpm. That concerns me and I've been assuming that I'll burn up my transmission if I have to maintain 2400.
But now I'm wondering if I'm overreacting.anybody have an opinion? Thanks.
Old May 10, 2017 | 10:30 AM
Alex_M's Avatar
You won't burn up your trans because the torque converter should be locked.
Old May 10, 2017 | 11:01 AM
Big Jim Swade's Avatar
I've found that my Disco is the worst tow vehicle I've ever driven. Mine does the same thing towing a 2 place atv trailer. I typically can't use drive on the highway, but usually I just leave it in 3rd. on the automatic. Changing to the stock tire height (or shorter) would probably help or changing the diff's to 4:10's would help the most.
importdave
Sep 25, 2014 10:18 PM
95_rover
Nov 11, 2012 05:59 PM
jmt
Oct 10, 2008 04:51 PM
BoostedAudi
Mar 16, 2007 09:39 PM
03se3
Freelander
Jun 2, 2005 04:07 PM
