Traction Control hiccup
Old Mar 24, 2008 | 01:26 PM
Scanner's Avatar
Default Traction Control hiccup
My 2003 DII with 82k has an intermittent hiccup when breaking. Basically when applying break (at any speed but mostly slow speed) every so often the T/C light briefly flashes and engages and then disengages. This also has a side effect of locking up my ScanGuageII ECU reader. Most often it happens at lower speeds like when approaching a stop sign or pulling into the garage at night. I had a similar problem on my RV (96 E350 Ford) and it turned out to be a broken ABS sensor. It does not throw any codes. How do I determine which wheel is the problem and what is the part I might need to replace called?
I’ve inspected the wires to the hubs but have not yet taken them apart to look at the sensors.
Old Mar 24, 2008 | 02:03 PM
Default RE: Traction Control hiccup
Get rid of one problem for a while, un plug the scanner.
So the ETC will flash while braking, do you feel anything if so describe in detail.
Are the 3 amigo are?
Old Mar 24, 2008 | 02:16 PM
Scanner's Avatar
Will unplug the scanner to see if that is somehow causing the problem.
When this happens there is a sudden and brief loss of brakeing power/pedal movement and increase in RPM. The pedal doesn't studder as though the ABS were kicking in it just get mushy but then quickly rebounds after the event passes a second or two later. The truck sort of lunges abit and then rebounds.
Its actually quite frightening especially going into the garage because for an instant you feel as if you are going to go through the wall and then the brakes come back.
Old Mar 24, 2008 | 02:21 PM
SpeedAgent's Avatar
Just a quick question- why are you driving with your scanner plugged in?
It sounds like a faulty ABS sensor to me, but odd it is not sending a error code.
Old Mar 24, 2008 | 02:35 PM
Scanner's Avatar
Its more than just a scanner. It reads the ECU in real time so you get all kinds of sensor info. Water Temp, Intake Temp, RPM, MPG, Engine Load, Voltage...etc
http://www.scangauge.com/
It just happens to also read and clear ODB codes.
Old Mar 24, 2008 | 03:02 PM
jdelp's Avatar
That thing looks pretty sweet, I saw someone else with one a while back. If it's accurately reading codes and giving you that info, I may installing one lower on the dash in front of the t-case shifter. How long have you used it?
Old Mar 24, 2008 | 08:51 PM
They are neat, can't read ABS issues and the less foreign stuff going on thru the ECU when you are having a problem the better of you may be.
stuckntx
Apr 22, 2015 11:20 AM
Externet
Jul 1, 2014 05:29 PM
adigerol77
Jun 7, 2011 10:48 PM
sloppyjoe
Mar 29, 2010 10:47 AM
rodrick smith
Apr 13, 2007 06:09 PM
