Traction Control Issues
Old Sep 10, 2020 | 01:21 AM
Black Dynamite's Avatar
Default Traction Control Issues
All,
Quick summary, my Traction Control kicks in when turning right while accelerating, and when turning right over bumpy surface.
Longer story: I had the Three Amigos. I did the shuttle valve bypass, and after using a ABS reader it showed a right front sensor code. I swapped out the sensor and the Amigos went away. Now I am having traction Control kick in only when turning right. I cannot tell if it is the rear wheel or the front wheel. What can it be? The tires are in good shape and don't have any odd wear patterns. The previous owner did a spring and shock lift. no change to the brake lines or front driveshaft. I am open to changing out the front steering linkage as I don't know the history on the parts anyhow.
Any suggestions?
Old Sep 10, 2020 | 08:05 PM
Fastercat's Avatar
Check it with an abs code reader again. It sounds like a wheel sensor
rmcc
Jan 24, 2019 08:09 PM
austinpriest98
Oct 3, 2013 10:00 AM
mwood2121
Sep 21, 2011 07:21 PM
mydisco03
Oct 27, 2009 03:25 PM
02DiscSD
May 19, 2008 07:29 PM
