Trailer wiring problem
Old Aug 5, 2007 | 02:32 PM
jbriggs's Avatar
Default Trailer wiring problem
I have a 96 Disco and I haven't been able to get trailer lights working on it ever since I bought it. My father owned it before me and had the trailer kit installed on it at a Rover dealer and it has never worked right. I have searched the web sight of the manufacturer (Hella) and it has been no help. Everything I tow is the flat 4 pin and mine is a seven round pin. I have the proper adapter, seven pin to 4, but it doesn't work. Thanks.
Old Aug 5, 2007 | 03:59 PM
Default RE: Trailer wiring problem
Has someone installed a trailer wiring control to the factoru plug assembly in the r/r quarter panel?
Mike
Old Aug 5, 2007 | 04:59 PM
jbriggs's Avatar
Yes it was installed at the dealer about 6 years ago before I bought it. I haven't pulled down the quarter panel yet that is my next step. I found an example to follow once I get it apart. I think they crossed some wires or didn't do something right when they installed it. Thanks.
Old Aug 5, 2007 | 07:01 PM
fire1427's Avatar
Pin 1 - Yellow LTurn/Brake
Pin 2 - Blue - Empty
Pin 3 - White Ground
Pin 4 - Green RTurn/Brake
Pin 5 - Empty
Pin 6 - Orange Reverse
Pin 7 - Brown Taillights
This link helped me out alot also... http://www.marksrv.com/wiring.htm
Old Aug 6, 2007 | 11:15 AM
jbriggs's Avatar
Thanks. The web site doesn't have the same type of connector but I think it pins out the same. I'm going to test it today.
Old Aug 6, 2007 | 12:02 PM
hobiecat's Avatar
Before you completely rip your truck apart, check the ground wire (usally white). Sometimes the corrosion breaks the connection.
I found this to be a problem with my wiring. All I do is remove my screw where my ground wire is. clean the metal, ensure the wire is clean and not broken then reconnect. I find with road wash under the the truck I have to do this every other year.
Good luck.
gruehle
Jul 27, 2020 09:10 AM
PedroNole
Jul 2, 2007 07:54 AM
MiniManiac
May 21, 2007 08:55 AM
PedroNole
Jun 28, 2005 12:50 PM
