Tranfercase Questions
Old Jun 2, 2008 | 09:49 AM
DiscoRui's Avatar
Default Tranfercase Questions
Hey guys i have an 03 Disco and as we all know there is no way to activate the CDL but to replace the whole transfer case, the question is would it be possible to swap transfer cases with an 04 model and if it is would that make the ecu act up or not?
Old Jun 2, 2008 | 05:22 PM
Default RE: Tranfercase Questions
I am 90% sure that you can put a '04 t-case into a '03 and I am 80% sure that the electrics are there, just need to be plugged in.
Old Jun 2, 2008 | 08:09 PM
You won't have any problems.
Old Jun 3, 2008 | 05:20 PM
DiscoRui's Avatar
ok thanks guys one more question do i need to change the driveshafts or not, sorry for the questions i just want to do it right.
Old Jun 3, 2008 | 05:32 PM
Disco2Guy's Avatar
Just the front d/s will need to be re-built if it hasn't already. The double cardon (the end by the t-case) should have 2 grease fittings like this. You should inspect the roto-flex coupler in the rear for any signs of cracking too. Keep it as a backup just in case.
Old Jun 3, 2008 | 06:03 PM
DII driveshafts fit all DII's and DI driveshafts fit all DI's.
Old Jun 3, 2008 | 09:54 PM
DiscoRui's Avatar
Sweet will get on it thanks a lot for the answers
avking
Feb 18, 2009 05:10 PM
Tvdmtac
Sep 19, 2007 08:28 AM
