tranny capacity
Old Dec 29, 2008 | 09:03 PM
tailchaser0527's Avatar
Default tranny capacity
Rave says 19.7pt (10 qt) to refill trans from dry..
How much does it take to do a drain and re-fill??
Old Dec 29, 2008 | 09:09 PM
Default RE: tranny capacity
Um, until it's full.
I think it is 6 quarts, buy extra, you can return what you do not need.
Old Dec 29, 2008 | 09:49 PM
Also, at my shop we have a chevron md 3atf fluid that says it's for all pre 2006 trannys that use dexron III ormercon fluids.
The reason I ask, is because it's basically free to me. Any doubts, and i'll stick to regular dexron III, thanks for any imput.
Old Dec 29, 2008 | 10:10 PM
I have no idea if that fluid will work or not.
If you try it and you are wrong, you are out $7,000. If it works then you saved $20.
Your call.
Old Dec 31, 2008 | 12:52 PM
You will be fine with that.
bigugly82
May 17, 2007 09:30 AM
apcollin
May 1, 2007 11:28 AM
adowgiert
Apr 17, 2007 09:43 PM
XBlade
Jan 19, 2007 12:40 PM
listed
Jun 12, 2005 06:57 AM
