Tranny Fluid and Gear Lube
Old Nov 11, 2008 | 07:14 AM
discobob's Avatar
Default Tranny Fluid and Gear Lube
Best recommendations for ATF and gear lube? Also, should all of the u-joints be repalced with greasable one's? It appears that only my front one is.
2000 Disco II 115,00 miles
Old Nov 11, 2008 | 08:42 AM
hazletbassist89's Avatar
Default RE: Tranny Fluid and Gear Lube
ATF I use Valvoline Maxlife full synth in my DI. Gear lube, I haven't changed mine yet, but I know Amsoil makes some good 75w-90 full synth.
And as long as the U joints in the front double cardon are greasable you should be fine, make sure to grease them at every oil change.
Old Nov 11, 2008 | 08:44 AM
Yes, all u-joints and replace the centering ball kit as well.
Gear oil should be synthetic for the diffs and t/case. Try using Vavolines high mileage Dextron .
1998DiscoverySE
Jul 20, 2012 08:02 PM
ljdiscovery
May 30, 2010 07:24 PM
LRScott
Mar 4, 2009 08:39 AM
freeland02
Engine & Internal
Nov 25, 2007 04:44 PM
twincharged
Jan 27, 2007 06:48 PM
