tranny fluid question
Old Jun 17, 2008 | 08:20 PM
jdelp's Avatar
Default RE: tranny fluid question
The rave instructions were followed as described above w/ the motor running, and I even had the front wheels up on some bricks to elevate it slightly. With motor running, pulling plug resulted in the above. All I can figure is that it was slightly overfilled. My dad had a good point, not sure how familiar you guys are w/ marine engines, but they'll often fill from the bottom drain plug and then close it up. I wonder if this is how they perform the service at LR?
[align=left] [/align]
Old Jun 18, 2008 | 07:07 PM
okdiscoguy's Avatar
I would think they would loose too much oil when they changed out the plugs in the bottom. When you fill up a lower unit, it is a small hole and you can stick your finger over it real quick. Not that easy on a tranny...
Not sure how it got so full..... weird..
redwhitekat
Dec 28, 2013 01:40 PM
1998DiscoverySE
Jul 20, 2012 08:02 PM
03discoman
Dec 28, 2009 08:29 PM
LRScott
Mar 4, 2009 08:39 AM
LiftedRover96
Feb 11, 2006 01:46 PM
