Tranny Fluid Volume Reqd. for Filter Change?
Old Dec 28, 2013 | 08:52 PM
04duxlr's Avatar
Default Tranny Fluid Volume Reqd. for Filter Change?
I've seen write-ups about filter changes that call for 7 or 8 qts. I just changed my tranny filter and when I drained the pan about 4 1/2 qts. came out. I put it back together and added fluid with it idling after shifting through the gears and it only took about 5 qts. before it was pouring out. Is this correct?
Old Dec 28, 2013 | 09:16 PM
jeffh's Avatar
I would re-check in a day or two. just to be safe.
Old Dec 29, 2013 | 01:40 AM
acg's Avatar
acg
This is correct. The reason that you are not using the full 7 to 8 quarts is due to some of the fluid remaining inside the torque converter part of the transmission assembly. There is no way to get it out without completely dis-assemblying the entire transmission unit.
Old Dec 29, 2013 | 07:59 AM
04duxlr's Avatar
I know that a filter change only gets what's in the pan. The cooler and torque converter remain full so you will only get a portion of the fluid but he total volume of the transmission is 19.7 pints which is just under 10 qts. Filter change write-ups say 7 to 8 qts. and I only used about 5 so I was wondering if anyone else had used this amount. The transmission shifts fine.
Old Dec 29, 2013 | 09:11 AM
TRIARII's Avatar
I may be doing my transmission fluid change today. Most people replaced around 4.5-5 quarts of fluid. Do it again in a couple weeks and you will probably get more of the old fluid drained. Review this thread: https://landroverforums.com/forum/di...uid-dii-23070/
Old Dec 29, 2013 | 09:16 AM
04duxlr's Avatar
Thanks. I only replaced about as much as I drained so I'm sure I have enough fluid.
Old Dec 29, 2013 | 02:12 PM
TRIARII's Avatar
Its a good idea to keep track of how much fluid drained and how much you put back in. Slid through all the gears several times and re check the fluid level then take the truck for a test drive - your set.
Old Dec 30, 2013 | 07:28 AM
drowssap's Avatar
as long as you checked it running it should be fine
Bmbarnum
Apr 20, 2018 12:08 AM
collin Barrows
Aug 28, 2011 07:13 AM
04BluDisco
Feb 21, 2011 09:54 AM
treant985
Dec 27, 2010 02:51 PM
LRScott
Mar 4, 2009 08:39 AM
