Radio issue (volume wont change/no sound)
Old Sep 22, 2013 | 01:37 PM
Bmbarnum's Avatar
Default Radio issue (volume wont change/no sound)
Hello all!
I just recently purchased a 2003 discovery about two weeks ago and I absolutely love the vehicle. Upon new ownership, there is no sound at all, and the radio volume **** on the radio does not change the volume up or down. Also, the volume control on the steering wheel does nothing, but the seek button works. All radio buttons work such as changing stations, etc. However, the volume **** will work to change the bass level and treble level.
A few things I've done:
Resetting the radio by unplugging the battery for 30 min.
Removed head unit to see if any plugs/wires were tampered with.
Located the amp (under drivers seat?) to see if it was a blown fuse but I did not see a fuse on the amp.
It is the stock radio unit, and I was hoping to fix it before buying an aftermarket radio. I have searched forums to troubleshoot but no luck.
Thanks in advance all!
Old Sep 23, 2013 | 09:58 AM
drowssap's Avatar
when you removed the head unit or disconnected the battery did it ask you for a code?
Old Sep 23, 2013 | 10:08 AM
The complete wiring diagrams in living color are in the "RAVE", the factory manual set, free download link below. Will show you all the fuses involved also.
Old Apr 20, 2018 | 12:08 AM
grimerica's Avatar
I had a similar problem with a 2006 lr3 HSE, I replaced al the blown fuses, pulled up the passenger door sill covers and discovered all the wiring soaking and submerged in water. I dried it all out and taped some corroded wires. The amp wiring is coated in a cover plastic. Works fine now. Water was coming in from broken sunroof drain line common problem. worth a look
oysterhead
Dec 28, 2018 09:47 PM
04duxlr
Dec 30, 2013 07:28 AM
collin Barrows
Aug 28, 2011 07:13 AM
Petes 03 Rig
Jan 5, 2006 08:13 PM
ssj4_yasir
Audio/Visual Electronics
Oct 12, 2005 08:59 PM
