tranny question
Old Feb 11, 2008 | 02:58 PM
semison's Avatar
6th Gear
Default tranny question
02 Disco 2 w/ 70000 mi......My last post involved a coolant leak and now that I think I have that stopped, it seems the tranny is giving me fits. The auto transmission is shifting early through all gears leaving me at a low rpm running in overdrive. It will shift first through overdrive before even reaching 30mph. When it gets into fourth/OD, it acts like it is sluggishly dragging and trying to accelerate (like if you were driving a manual and accidentally shifted into 5th gear when trying to hit 3rd OR like you were riding on a flat tire). So, I thought it might be that the tranny was losing atf somehow or that was a sign of time to change. I bouoght the truck about 5000 mi. ago and have no knowledge of the previous service done to it. I pulled the check plug and it was full, but the atf was a dark brown. So, I changed the fluids and added Lucas. It still has the same problem. Any ideas? Much appreciated.
Scott in Mississippi
Old Feb 11, 2008 | 08:07 PM
Default RE: tranny question
I have heard of this happening on another forum, but I do not know what the problem was.
www.discoweb.org, do a search and maybe you can find it, I will go look for a minute but I have to tell you that I have the attention span of a 2 yr old.
Old Feb 11, 2008 | 09:08 PM
Get to a small tranny shop and have them plug in their scanner to see what is going on.
Old Feb 11, 2008 | 10:26 PM
elrocha69's Avatar
This is the same problem I am having. As soon as I put the engine in the dealership is supposed to fix it, although it has been there for the same problem numerous times. Does your mode selector work ( Sport/manual ) located on the shifter console? Mine works when it wants to but they insist its dirty. they have ceaned it a few times and it still doesnt function properly. I am wondering if that may be the culprit. If I am not mistaken our trucks use the bulletproof ZF 4hp22 transmission, which my 85 745i uses and I am pushing almost 400hp to the rear wheels an about 496lb/ft torque to the rear heels, so they are very strong transmissions. I am guessing it is in a default mode due to a lack of signal telling it when to shift relative to throttle position and engine RPM. I'll post something as soon as I find the culprit. It's good to know that I am not the only one with this problem. I was about to just accept that this was the wasy they shifted to increase fuel economy. I gues I'm not crazy after all.
Old Feb 11, 2008 | 10:31 PM
okdiscoguy's Avatar
Forgive my ignorance on D2's, but you mentioned coolant leak. Throttle body? Don't you have a kickdown cable running from the throttle linkage? I know on my D1, I do and it is touchy. Could be adjusted wrong or changed when you worked on the throttle body.
Just a shot in the dark.....
Old Feb 11, 2008 | 10:34 PM
elrocha69's Avatar
If I'm not mistaken the Disco II doesnt have a Kickdown or Detent Cable. I didn't see one on mine, all I saw were the trottle and cruise control cables, but I will look when I get mine back at the shop and start removing the engine to replace it.
Old Feb 12, 2008 | 08:47 AM
semison's Avatar
6th Gear
Thanks for the replies. I'll check the kickdown cable on the throttle body, but I am like elrocha69 and am not sure that the d2 has a kickdown cable. I'll see. It's funny, it hasnt given me any codes or warning lights, though. It is not drivable in this condition. I'll try to get it to a tranny shop and let them see what their scanner says. More research to come.
Old Feb 12, 2008 | 09:09 AM
D2 trannys are electronic and the shift points are controlled by the ECU and the tranny contol unit, so don't go looking for cables to adjust.
Take it to a small tranny shop, not the dealer and have them scan the system for problems.
jm12503
Nov 27, 2008 06:08 AM
ajordan_0012000
Oct 7, 2008 09:23 PM
tampa buyer
Oct 5, 2008 07:39 AM
jdelp
Jun 18, 2008 07:07 PM
bavarian_range89
Oct 25, 2007 07:09 PM
