Trans and towing
Old May 21, 2007 | 01:16 PM
XBlade's Avatar
Default Trans and towing
I'm towing about 3000-3500lbs. I read the manual and there's nothing mentioned about what gear I should be pulling in. Alot of vehicles have a tow button that will limit shifting and such.
Should I put it in 3rd or let it ride in drive? I've been using drive and it tows fine I just don't want to damage anything.
X
Old May 21, 2007 | 01:36 PM
Default RE: Trans and towing
It will depend on the type of road you are driving on. If it is a flat highway and the engine is not pulling too hard don't worry about it, if you need some help, drop it to 3rd and you'll be fine. Don't forget to throw in a good bottle of gas additive to clean out your engine while out there on the road, it will be great for it.
Mike
Old May 21, 2007 | 01:38 PM
wbstyles's Avatar
Manual tells you to tow in gear selection 3. This will prevent any damage to O/D. That is my two cents worth.
Old May 21, 2007 | 02:29 PM
XBlade's Avatar
WB,
I have an 03 Disco and I couldn't find any reference in the manual about towing in a lower gear. It states that if your towing at less than 20mph to shift to low range on the 4 wheel drive deal.
Mike,
I've been putting in a bottle of Seafoam at every oil change. Would it hurt to use Seafoam or another fuel additive more often?
X
Old May 21, 2007 | 03:19 PM
You are over doing the additive. Save your money and do the fuel additive ever 6 months or so unless all you do is city driving the I might do it a little more frequently.
Mike
abran
Apr 27, 2014 06:59 AM
Optimusglen
May 25, 2013 09:51 AM
tbesselman
Feb 13, 2012 07:01 AM
Draayer
Jun 7, 2011 08:06 PM
The People Family
Aug 6, 2008 10:32 PM
