transfer box filler nut removal?
Old Apr 28, 2009 | 06:56 PM
sharp's Avatar
Default transfer box filler nut removal?
2001 disco
Any ideas how I can loosen the filler nut. Spent a while today couldn't get it loose. I used the 1/2 head. Sprayed it with liquid wrench, let sit for 1/2 hour, then repeated. No help. Tried to hit wratchet down with a hammer but couldn't get leverage. Any ideas would be appreciated.
Thanks
Old Apr 28, 2009 | 07:00 PM
Disco Fuego's Avatar
That thing is a PITA! I had the same problem and resolved it as follows:
I used the wobble extension and attached a long torque wrench that gave me lots of leverage. I put my foot on the end of it and slowly started adding pressure. It did come undone...
Hope that helps!
Old Apr 28, 2009 | 07:09 PM
Breaker bar and grunt when you pull on it.
Old Apr 28, 2009 | 07:14 PM
Originally Posted by Disco Mike
... and grunt when you pull on it.
LOL Just make sure you're alone when you do...
Old Apr 28, 2009 | 07:33 PM
The metal filler plug and aluminum case dont like each other and will corrode and stick.
Apply anti-sieze on the threads when you put it back together.
Old Apr 28, 2009 | 08:48 PM
sharp's Avatar
Thanks for the ideas. I'm going to give it a second go around in a couple days. Supposed to rain here tomorrow.
Old Apr 28, 2009 | 10:36 PM
llPANCHOll's Avatar
Righty Tighty
Lefty Loosy
Old Apr 29, 2009 | 08:10 AM
britishdiscovery's Avatar
I have just done mine, and found the same problem. Use a 21mm socket, the hexagonal type rather than the 'star' type. Press down hard as well as turning the ratchet. This should prevent the plastic head from stripping.
Old Apr 29, 2009 | 08:29 AM
JBEGIN's Avatar
do what Mike says, and dont poop yourself when you push on the breaker bar...
Old Apr 29, 2009 | 10:29 AM
Disco Alan's Avatar
Just did mine this past weekend. My wrench is 3/8" drive so I used a 2" extension and then a 3/8" to 1/2" conversion. After setting the wrench in the filler plug I went sideways under the truck - my head sticking out the passenger's side with my left foot on the left rear trailing arm and right foot somewhere on the ladder frame for leverage. Then both hands on the wrench handle and dead lift sideways.
I agree a short breaker (12" or so) would have helped a lot. If you don't have one go to Home Depot and find a right size pipe and have them cut it to the length of your choice.
