transfer box filler nut removal?
Old Apr 29, 2009 | 12:51 PM
antichrist's Avatar
Originally Posted by Disco Fuego
I used the wobble extension and attached a long torque wrench that gave me lots of leverage.
Remind me to never lend you a torque wrench.
Old Apr 29, 2009 | 12:57 PM
antichrist's Avatar
Originally Posted by Disco Alan
Just did mine this past weekend. My wrench is 3/8" drive so I used a 2" extension and then a 3/8" to 1/2" conversion.
How did you fit all that between the back of transmission brake and the transfer case?
Old Apr 29, 2009 | 02:44 PM
Disco Fuego's Avatar
That's funny, it was actually one that I had borrowed from a colleague! Didn't break it, and by the time I got to thinking of using that, I was so pissed at the nut, that I didn't care what tool I was using anymore. Obviously I would have replaced it if I had broken it...
Old Apr 30, 2009 | 11:43 AM
Disco Alan's Avatar
The 2" extension for my 3/8" drive wrench is pretty skinny and it moves the wrench just enough away from the filler. The whole set up sits at a slight angle but probably not any worse than using a wobble. I put the 1/2" square adapter into the filler plug first to make sure it sits nicely, then the extension, finally attaching the wrench. I also think that the tolerance gap between the adapter and the extension gives me that slight angle that I needed.
Old Apr 30, 2009 | 06:20 PM
grussell's Avatar
This is what I used and I had it out in just a couple of minutes.
Attached Thumbnails transfer box filler nut removal?-transfer-case-fluid-change-005.jpg
Old Apr 30, 2009 | 10:12 PM
sharp's Avatar
Finished her up today. Used a 1/2 wratchet with the universal head, I attached a 10" 3/4 pipe to the wratchet for additional leverage. She went just fine after that. Applied anti seize to the filler bolt so she doesn't give me too much trouble next time. Over all, not too bad of a job once the bolt was removed.
Thanks for all your help, it solved this problem.
Old May 12, 2009 | 01:42 AM
Wolkesan's Avatar
Default What about the drain?
Transfer box filler nut- No problem. The drain plug I can't get to. Tried every thing I have, and drove to multiple auto/hardware stores and couldn't find anything that would fit past the cross member.
What do you all use? The only thing I have found that might work is a socket cap set.
far4cges
Aug 6, 2012 08:25 PM
bostongrun
Apr 15, 2012 09:55 AM
Willie00d2
Sep 21, 2010 07:35 AM
ant996
Defender
Sep 14, 2006 05:03 AM
imag
May 12, 2006 07:59 PM
