Transfer Case
Transfer Case
I'm having my transmission and transfer case replaced with a used lower mileage set. My mechanic just called and said the transfer case has 2 extra electric connectors on it. Will this transfer case work on my 2002 Disco 2? I got the transmission and transfer case off a like model.
Thanks for any guidance!
t case
Beware on these used t case they will all be bad close to 100,000 miles and dont belive a junk yard that sales them as good unites .Had two go bad in the past 20,000 miles so i rebuilt the next one. These have eight bearing in them take it to a shop that works on t case and rebuild it 250 for parts plus labor.
Mel, an 04 case will work with your truck, will you also be getting the shift linkage?
You will need to get a little creative with the wiring because the 04 has a different shift solenoid, but you can work around pretty easily.
Braxton, what you need to find out is what year that t/case came out of. You only want a G2 t/case from a 99, 2000, 2001 or a 2004, do not use one from a D1.
When you say you got it off a like model, doesn't tell us what year. Are you wanting the CDL, if so don't forget you will need a D1 or an 04 shift assembly.
