Transfer case failure
Old Apr 9, 2012 | 11:55 AM
SolbergFanBoi's Avatar
Originally Posted by Spike555
Things happen, even properly maintained parts fail, never eat candy and you can still get cavity's.
Haha touche!
Originally Posted by Disco Mike
Then, yes, I agree no since spending the money on an 04 case. Make sure to start running either a 75 or 85/140 gear oil for extra protection.
Will do Mike... Thanks again for the insight everyone. Will post results.
Old Apr 9, 2012 | 07:02 PM
Quick question... Many available transfer cases state "w/o lever'' meaning some kind electronic engagement of the transfer case? Mine has the little boot that manually operates the transfer case. Are they compatible? My initial feeling is no or this feature doesn't exist...
Old Apr 9, 2012 | 07:57 PM
The lever is what is ontop of the t-case that attaches to the shifter inside the cabin.
The '04 uses a cable, the DI uses a linkage.
If all you are ever going to do is drive it down the road and never need lo or any of the CDL gears you do not need the lever on the t-case.
You can buy the lever separate, e-bay for example.
A DI lever will work on any t-case.
Old Apr 9, 2012 | 09:07 PM
discoweb.org -- has a write up on replacing the bearings on the output shafts, just something to consider.
Wayne
Oct 2, 2020 12:10 PM
mj_duell
May 2, 2012 10:16 PM
markp
Feb 8, 2006 05:48 AM
Loose_Screws
Jul 22, 2005 12:13 AM
Smokeyone
Jun 4, 2005 03:11 AM
