Transfer case front ouput shaft play
How much play is normal on the front output shaft? I recently replaced my front driveshaft after experiencing the typical vibration. In the process, I noticed that the front flange of the transfer case had a lot of play. Should it be able move side to side?
2004 Land Rover Discovery
No play should happen, sounds like the output bearing is bad, replace right away, or you will go through UV joints, and you run the risk of causing savere damage to other parts in your transfer case.If you are handy, and some tools and info ,this shouldnt be a real hard job to do, I have repaired other transfer cases in other trucks, this shouldnt be any harder.
Thank you for the quick reply. I was afraid of that. Do you know what the part numbers would be? I assume I need a bearing and a seal, but I can only find the seal at the usual part sources. Hopefully I do not have to special order anything, because I am supposed to leave for Moab on Wednesday.
powderhound
07-07-2014 10:51 AM
EstorilM
10-11-2011 08:13 PM
