Transfer case front ouput shaft play
Old Apr 17, 2011 | 11:51 AM
sharpshooterjohn's Avatar
8th Gear
Default Transfer case front ouput shaft play
How much play is normal on the front output shaft? I recently replaced my front driveshaft after experiencing the typical vibration. In the process, I noticed that the front flange of the transfer case had a lot of play. Should it be able move side to side?
2004 Land Rover Discovery
Old Apr 17, 2011 | 01:19 PM
ajmille's Avatar
No play should happen, sounds like the output bearing is bad, replace right away, or you will go through UV joints, and you run the risk of causing savere damage to other parts in your transfer case.If you are handy, and some tools and info ,this shouldnt be a real hard job to do, I have repaired other transfer cases in other trucks, this shouldnt be any harder.
Old Apr 17, 2011 | 03:39 PM
8th Gear
Thank you for the quick reply. I was afraid of that. Do you know what the part numbers would be? I assume I need a bearing and a seal, but I can only find the seal at the usual part sources. Hopefully I do not have to special order anything, because I am supposed to leave for Moab on Wednesday.
Old Apr 17, 2011 | 04:15 PM
You don't neede a part number, either go on line to Toddco, British Atlantic or call your local dealer.
Old Apr 20, 2011 | 12:07 AM
8th Gear
Turned out to be a loose nut on the output flange. My thanks go to Bill at Great Basin Rovers for diagnosing my problem. I still need to replace the seal, but the bearing is good. I have no idea how the nut loosened on its own.
Old Apr 20, 2011 | 07:11 AM
antichrist's Avatar
It may have been removed and reused. New ones should be fitted when the nut's been removed for any reason.
powderhound
Jul 7, 2014 10:51 AM
xmarksit
Nov 26, 2013 08:37 AM
cookci
Nov 3, 2013 08:49 AM
caymandrew
Jul 8, 2013 03:24 PM
EstorilM
Oct 11, 2011 08:13 PM
