Transfer Case Interlock Solenoid delete?
Old Sep 24, 2025 | 11:36 AM
Harvlr's Avatar
Default Transfer Case Interlock Solenoid delete?
Can I just remove this solenoid? Is it a good idea? I’ve torn apart my Hi/Lo shifter and cable as I couldn’t select Low Range last time I tried. It seems to me that now that I’m this deep I should remove this solenoid as I wonder if it’s the problem.
Old Sep 24, 2025 | 05:42 PM
Harvlr's Avatar
I found an old thread about this, so I’m going for it
Old Sep 25, 2025 | 12:03 AM
T-rex's Avatar
Deleted mine about 10 years ago - never had a reason to wish I hadn't.
Old Sep 25, 2025 | 12:21 AM
Harvlr's Avatar
Thanks TRex. I removed it. I haven’t finished putting everything back together yet.
Old Sep 25, 2025 | 09:11 AM
sqlbullet's Avatar
Mine is gone. In fact it's on a cabinet to my left. Dead as a door nail.
Old Sep 25, 2025 | 01:29 PM
Best4x4's Avatar
The 03/04 setup = on the h/n/l assembly vs on the TC itself. I simply used the 04 CDL linkage, removed the interlock on the TC while I was upgrading to CDL, and just plugged the interlock in and all done.
Old Sep 26, 2025 | 10:06 AM
Harvlr's Avatar
Thanks Best. I removed the Solenoid and did not plug it back in. It seems to work fine. My shifting from Hi to Low, and CDL work better than they have since I’ve had the machine. The linkage and cables did need some lube, but nothing was seized. That may have the main problem, but now the Solenoid will never give me a problem.
Mine is an ‘01 which still had the CDL in the T-case, with a shifter and SLABS from an ‘03.
Erikleonard
Dec 27, 2023 01:35 PM
Harold Espinal
Jun 27, 2020 02:29 PM
elboy0712
Jun 26, 2020 02:28 PM
moncton_vw
Sep 16, 2011 05:55 PM
ajh
Oct 5, 2007 07:01 PM
