Transfer case leak
Old May 13, 2013 | 10:28 PM
Bob Loblaw's Avatar
Default Transfer case leak
After a rare 7-hour drive at ~75 mph, I noticed that the transfer case is leaking gear oil and the oil is being blown all over the rear part of the undercarriage. I know a leak from the cover plate on the t-case is common, but I'm not convinced the leak is coming from there. I think the leak is coming from the seal pointed at in the picture, but I can't be sure. I've read in other threads about putting the White Shepherd oil stop leak in there, but I wanted to make sure that is the right approach in my case. I'm not even sure what that piece is called that may be leaking.
Any advice on what to do?
The aggravating part is that the truck was driven all that way so that I could replace the radiator, hoses, water pump and gasket, timing cover gasket, timing chain, crankshaft and camshaft pulleys, oil pump gasket, oil pump pickup seal, and tires. Now I seem to have 1 more issue to chase down.
Old May 13, 2013 | 10:54 PM
Dogfan's Avatar
I had the same problem on my 03 Disco. I cleaned the case with degreaser and then drove it around my nieghborhood at slow speeds so the oil would leak without blowing everywhere. I found it leaking out of the o-ring in the middle of the case. I can't remember the name of the shaft but you can see the bolt that holds it in above the fill plug. Mine was leaking in front. If this is where it is leaking you will have to drop the case out and change them. The best deal is to buy the whole gasket kit below. it is a beast of a job!
Transfer Box Gasket & Seal Kit LT230 (Part # RTC3890) - Land Rover kits from Atlantic British
Old May 13, 2013 | 11:07 PM
bballjames's Avatar
That is one clean t case
Old May 14, 2013 | 06:16 AM
drowssap's Avatar
you could try some White Shepard stop leak, they sell different formulas. I used the one for transfer cases about 1.5 years ago on my RRC transfer case and it worked well. might be worth a try.
Old May 14, 2013 | 09:31 AM
Bob Loblaw's Avatar
I'm a little confused on what formula to buy. Could someone point me in the right direction?
This?
White Shepherd Rear Main Sealer (8 oz.) - BLU00234
Or This?
Buy White Shepherd Oil Stop Leak 49499 at Advance Auto Parts
Or does it not matter?
Old May 14, 2013 | 09:46 AM
drowssap's Avatar
I believe I used this one in my transfer case
ebg18t
Jan 14, 2012 01:55 PM
rancher43
Jul 27, 2010 05:15 PM
Tapper
Feb 3, 2009 09:35 AM
mrjcrew
Apr 24, 2008 06:45 PM
Td5
Sep 1, 2006 05:01 PM
