Transfer case move vs. drop question
You remove the round plate on the back of the TC (PTO Cover in diagram above), remove Transfer gear set and you are looking right at that #5 bolt. Remove it and out comes the transmission output shaft. Making for a very effortless TC removal job. That and removing the entire Ebrake assembly makes it a very straight forward job.
Richard Gallant (08-24-2021)
Yep, that's it. O-ring seal at the front gets hard and brittle over time, leaks. Put new o-ring on, slather it with hi-torque silicone (gray stuff), and put it back in. Tight nut another 1/4 turn and let her rip.
You can of course reset the preload if you desire, however if you re-use the existing nut and turn just an 1/8 to 1/4 turn past the original staking point you are essentially coming back to the original preload. When the preload is set on the original bearings it is based on zero wear new bearings, I assume yours have 100k+ wear on them so a small amount of additional preload essentially compensates for that.
Kenso
10-28-2014 09:05 PM
