Transfer Case oil question.
I know that the workshop manual calls for 75/90 oil for the transfer case, but I've seen references to other people using a heavier t-case oil. My DII has almost 150,000 miles and I'm about to add some Blue Devil to the transfer case in an attempt to solve a leak issue. Is there any advantage to using the heavier oil?
I switched to 85-140 dino oil for better protection. Just check up on it once a year or so. Theres a recommended additive to use for leaks on the forums. I used it and it worked great. I forget the name of it but I'm sure it'll come up on a search.
I work at a dealership, we buy it in bulk, and it costs me almost nothing.
Much cheaper than a new transfer case.
How did you guys pinpoint that you have a leak in the transfer case? Process of elimination by going underneath and cleaning everything off? I have a leak and I'm trying to pinpoint it but there's a mess under there. It's not leaking much but enough to annoy me.. I don't like leaks.
If its thick gear oil and its showing up on your t-case or dripping near the middle of the vehicle then its probably the t-case leaking. Just make sure its not ATF (red, smelly, and thinner than gear oil) or just wind blown motor oil landing on the t-case and crossmember, I think my truck does a little of this since its wet around the rear mail seal and also around the t-case. I loose motor oil slowly (<1qt between 3,000 - 4,000 mi. oil changes) and the t-case doesn't loose any noticeable amount.
I would just keep an eye on fluid levels like you should anyway. Unless its a measurable amount of motor/gear oil or any coolant/ATF leak its probably not worth fixing.
A Landrover without an oil leak is like a woman without attitude
Present company accepted or excepted
Difficult one KD, the only real way is to wash off the T.case, diffs, engine and autobox with a soluble degreaser and then jet wash the underneath go for a short drive, say 20 miles and then recheck for leaks.
I'll do that, thanks Offroad
haha.. this woman definitely has an attitude - more days than not
disco12
Mar 6, 2006 05:02 AM
