Transfer case plug - How Tight?
Old Sep 7, 2010 | 05:27 PM
Knobcents's Avatar
Default Help! Transfer case plug - How Tight?
Quick question - doing the gear oil change on my 03 T-case and confused on how tight the drain plug should be. Rave shows a bolt style plug which calls for Loctite 290 and 22 foot pounds. My plug is like the fill plug with no "stop" or "Shoulder" - it just keeps screwing in and at some point feels like it might contact an internal t-case gear. So I have wrapped teflon tape on the plug - Should I tighten until plug is flush with the case? Or should I tighten it further?
Old Sep 7, 2010 | 07:24 PM
Flush no deeper than flush.
Old Sep 7, 2010 | 09:43 PM
vandev's Avatar
Default i could be wrong...
i could be wrong and usually am...but if your an averaged sized adult ...and laying on your back under a truck....about as hard as you can turn in that situation is what works best.... never had a transfercase hipupk a drain bolt...
Whats a torqe wrench....
Old Sep 7, 2010 | 09:57 PM
agthird's Avatar
don't over torque it or the next owner will curse you....
JB99Disco
Feb 18, 2011 09:38 AM
svntsvn
Jan 10, 2011 07:47 AM
Disco Fuego
Mar 22, 2009 05:18 PM
barbarosa
Feb 9, 2009 06:49 PM
hriant88
Apr 19, 2008 09:27 AM
