transfer case seal leaks stopped!
Old Jul 15, 2008 | 02:08 PM
ljdiscovery's Avatar
Default transfer case seal leaks stopped!
My 99 Disco I has been suffering from unintended transfer case fluid discharge (seal leaks). Seal redo was qouted at $1200. I checked my local Kragen and found a product White Shepherd from Univeral Products (also makes Blue Devil and Red Angel, see a theme here). Anyway, thought what the heck, paid my $32 and put it in. Long story short, it worked! It took about 3 hours of driving over a couple of days, but the tranfer case is now dry as a bone. Hopefully we won't have any long term problems but so far I couldn't be happier. Now to figure out how to get the gear oil stains off of the driveway. Thanks Phil
Old Jul 15, 2008 | 03:05 PM
NiteTrain's Avatar
Default RE: transfer case seal leaks stopped!
If that stuff made your gear oil thick enough not to leak it might not be good for your gears..the gears are engineered for a certain oil viscosity. $5 worth of RTV will fix a TC case leak.
Old Jul 15, 2008 | 03:20 PM
it is actually didn't change the thickness of the gear oil at all. Seems to be just the same. The White Shepherd is about the vescosity of water. I will keep you posted though. Long term will tell. Phil
Old Jul 15, 2008 | 04:04 PM
The best way to remove oil stains is with carb cleaner. Muratic acid works well too.
Old Jul 15, 2008 | 08:21 PM
NiteTrain's Avatar
Be careful with muratic acid, me and a friend acid stained his basement with that stuff and it's fairly toxic. I saw some driveway oil removed on some auto show the other day, it went on wet then absored the oil and dried up...I can not remember the name though.
TOM R
Jan 25, 2023 10:17 PM
Spencerfitch
Sep 27, 2020 12:17 PM
FlyingZebra34
Apr 22, 2013 12:07 AM
jfall
Mar 21, 2013 02:30 PM
yloDiscoII
Feb 10, 2010 10:03 PM
