transfer case solenoid
Old Sep 25, 2007 | 08:05 PM
jutgin's Avatar
Default transfer case solenoid
Can't shift into low. I have heard you can remove solenoid from under console?
Justin
Old Sep 26, 2007 | 05:19 AM
dirtyduk's Avatar
Default RE: transfer case solenoid
Tough to get to it. Is the gear box in netural ? try it while rolling slow (under 5mph). the leaver might be seized in the housing .
what ever you do with the solenoid or theshift leveryou will be removing the console and a riveted access plate to get to it.
Old Sep 26, 2007 | 06:21 AM
jutgin's Avatar
Yes I've tried it every way imaginable. I believe the solenoid is either seized or doesnt have power from the relay or something else? My thought is to remove it, its not needed really its just for safety but I dont think i'll try to shift to low while driving! I just thought it would be easier than dropping the t-case!! I've got it stripped down to the riveted plate but dont know if its worth continuing, if its under there it would be, but is it there???
Old Sep 26, 2007 | 05:22 PM
Justin,
Do you have a D1 or D2?
Old Sep 26, 2007 | 07:39 PM
dirtyduk's Avatar
Yes , important question D1 or DII , one dosent have the solenoid, but either way your right there, drill the rivits and go in man ! [>:]
If the shifter is frozen you need to access it.( D1) If the solinoid is dead you need to test for power signal ( DII )
Old Sep 27, 2007 | 08:18 PM
jutgin's Avatar
Hey guys sorry I havent been on much lately. I have a 2003 disco 2. I'm taking it to a mechanic tomorrow who said he doesnt need to drop the t-case or take apart the console????? Said he can reach up there and take the bolts out???? So I guess I will see how that goes.....
Justin
Old Sep 28, 2007 | 10:54 PM
jutgin's Avatar
Yup he was right. You dont have to drop the transfer case or take out the console. Didn't take him long at all. If you're near Chattanooga, TN and need work go to Outback Off-road center!!!
Justin
Jupe209
Feb 4, 2026 06:19 PM
moncton_vw
Sep 16, 2011 05:55 PM
twaszak
Jun 27, 2011 01:32 PM
stanigu
Aug 30, 2007 11:43 AM
