Transfer case stuck in neutral
Old Apr 24, 2015 | 01:49 PM
Black01D2's Avatar
7th Gear
Default Transfer case stuck in neutral
Hi all! New to landrovers but not to offroading...I had Jeeps for many years and now have a K5 Blazer and an 01 Discovery 2 v8 se. I just picked the discovery up this am. I got it at a junkyard where it was purchased from an auction. It is in good shape and there's a lot of records for it on work done. It had a driveline noise (whine) like it wasn't all the way in gear and the t case neutral chime was on but it would go off when driving when you let off the gas or put it in reverse. After driving it a little but it went into neutral on the t case and it will not shift at all (the trans shifted when driving). At that time the key got stuck in the ignition (I did find a bent penny under the trans shifter too). I did a lot of searching and have removed the center console and shifters/floor pan and can see the top of the trans/tcase. It seems like the t case could be bad but im hoping for a bad solenoid. It does not have the CDL option. Am I on the right path here? Also what tcase is this exactly. Thanks for the help!
Kevin
Old Apr 24, 2015 | 04:53 PM
Bom2oo2's Avatar
If U R sure it's t-case and not transmission that's broke, go under truck and follow cable to t- case to find linkage and try shifting it from there it can go to hi/neutral/low. If it worked then U R lucky(nothing is broke) and only cable is stuck, check t-case gear oil b4 driving again. Also check transmission fluid while at it ,( needs to be done from under truck while running in neutral position).
Old Apr 24, 2015 | 05:07 PM
Black01D2's Avatar
7th Gear
Bom2oo2, Thanks for the reply. I have the console out and can see the t case shifter. It looks to move but only a little in each direction. The t case has oil, didn't check the trans yet but I did get it back into hi gear on the t case while this happened this am but only for a second (I was pushing and pulling as it was in neutral and I pulled it into hi and out right away then it wouldn't go back in. If I need a t case I found them locally for $100 with $75 core with a 3 month warranty. Still hoping its the solenoid...
Kevin
Old Apr 24, 2015 | 05:25 PM
Bom2oo2's Avatar
It will shift easier with truck running in neutral, and rolling at couple mph, does it go to low range at all? If buying a used t-case, try getting one that has CDL like your's does (a nipple on top front left ), then u can make a linckage for it later and use the benefits of CDL.
Old Apr 24, 2015 | 05:35 PM
Black01D2's Avatar
7th Gear
It went in low hi and neutral when I checked it 2 weeks ago (was waiting for the title 'til today), although the whole time the t case neutral light was on and chiming. When I put it in reverse and backed up it would go out. If I go with the new used t case I definitely would go with the one with the CDL and then add that feature later.
Kevin
Old Apr 24, 2015 | 06:47 PM
OffroadFrance's Avatar
x1 LR states it's better to shift the low range t case when rolling up to 5mph as often when stationary it's impossible to shift the lever. Problem with low/hi range on the t case is if it isn't exercised regularly, say once a week, it seizes up permanently.
Old Apr 24, 2015 | 06:52 PM
Black01D2's Avatar
7th Gear
My cj7 was like that. I would have to push on the t case shifter and let the clutch out while in 1st to roll a little to get it into low. Thinking about the discovery transfer case and from what ive read I'm thinking its bad. Going to pick up a used one tomorrow am with 70k on it.
Old Apr 24, 2015 | 06:55 PM
Bom2oo2's Avatar
remove the solenoid from top (trans tunnel) if u can, and put square cover back, then try shifting again if its broken solenoid that should fix it, but then U will loose the safety-net (it can shift into low while driving if U push the hi/low lever) but then U will know if broken solenoid or something else.
Bobcat9024
Mar 29, 2022 03:36 PM
Discomini
Dec 20, 2014 06:01 PM
powderhound
Jul 7, 2014 10:51 AM
ImQuattro
May 1, 2014 08:36 PM
lordmorpheus
Jun 13, 2012 05:11 PM
