Transfer Case switches
Old Dec 6, 2019 | 09:25 AM
ahab's Avatar
Default Transfer Case switches
The Hi/Lo and Diff lock indicator lights aren't functioning in my 04. I'm pretty sure this is preventing HDC from operating, since the system isn't aware I'm in Low. Diff lock and Low are definitely working, I just don't get dash lights so I'm suspecting the switches. The PO never used either in 14 years so perhaps they're stuck or something. Anyway, I've got the trans and transfer case out and I've gone through the Electrical Library and the ETM but I'm having trouble identifying which switches do what. My understanding is that there should be four switches on the 04 however the pics in the Elec Lib do not line up with what I find on mine. Is this even close? TIA
1 = Neutral
2 = Hi/Low
3 = Diff Lock
4 = Diff Lock
(List edited to number the switches correctly)
Old Dec 6, 2019 | 09:46 AM
Red5's Avatar
Switch 2 is the Hi/Lo. My '04 had the same trouble with HDC and replacing that switch with the green lead fixed mine. You can check continuity at the plug to verify. Hi=Open, Lo=Closed (I think).
Nos 3 and 4 are for the dif lock.
Old Dec 6, 2019 | 10:16 AM
ahab's Avatar
Thank you for the reply. That would make sense as the 03 transfer case I have does not have switches 3 and 4. It would also make sense that the trans temp switch would be on the actual trans...
Anyone know what number 1 is for? According to the library it looks like it is a neutral switch. The switch itself is obscured but I think the blue wire goes to it, and it is present on both transfer cases I have.
Edit: Does anyone know where to find the diff lock wiring in either the ETM or the Elec Library?
Old Dec 6, 2019 | 10:49 AM
ahab's Avatar
OK, this clears up a lot of my confusion. The other docs I have don't seem to reference the the 04 whereas the Workshop manual does. The diff lock switches are not only different specific to 04 with molded plugs instead of spade-type connectors, there are also two of them for some reason. Hooray. I'm still looking for the electrical schematic to find out how they're wired in but at least now I have confirmation where everything is. Switch number 1 in my pic above isn't shown in this view but it is indeed the neutral switch.
acg
Apr 28, 2020 12:53 AM
Jeff Blake
Jul 8, 2018 01:47 PM
KlamathMatt
Oct 20, 2014 02:24 PM
dcarr1971
Jan 27, 2012 10:31 AM
Danny Lee 97 Disco
Apr 15, 2010 07:20 PM
