Transmission Fluid Fill
Old Jun 18, 2012 | 05:48 PM
FLDiscoII's Avatar
Default Transmission Fluid Fill
Maybe I'm tired, so this might be a stupid question. I noticed that one of the six bolt fasters one the trans oil pan was broken, causing a slight ATF leak. I replaced the fastener and have a good seal now. While I was under the truck I thought I'd check the fluid level and top it off if necessary. But when I pulled the fill plug, about 1/2-3/4 quart spilled out. The truck had been sitting for a few hours, and I changed the filter/gasket/fluid about 2 months ago. I followed the RAVE guidance for how much to refill it with, but obviously didn't get the full 9.8 quarts in. Any ideas why so much spilled from the fill port 2 months later?
Old Jun 18, 2012 | 06:02 PM
Bkreutz's Avatar
Did you have the engine running and up to temperature when you checked it? (that's how it's supposed to be checked, if the engine wasn't running it will pour out the fill plug)
Old Jun 18, 2012 | 06:04 PM
drowssap's Avatar
you need to fill it back up until it starts running out the fill hole with the engine running.
you change the fluid 2 months ago there is no need to drain it all again.
Old Jun 18, 2012 | 06:06 PM
nychaze's Avatar
1. Drain Fluid
2. Fill through top plug until fluid pours out
3. Start truck and shift to R and D a couple of times and back to park
4. While truck is running in P, go back under and add fluid until it pours out.
5. Done deal, go get the truck muddy
Just changed mine last Friday.
Old Jun 18, 2012 | 10:33 PM
FLDiscoII's Avatar
Haha, talk about a laugh at yourself moment. I remembered to put my keys in the ignition before I got under the truck but not to start it. Sometimes you just need someone else to catch those dumb moments for you.
Old Jun 19, 2012 | 07:29 AM
James, just so you also know, the average drain and refill is only between 5 and 6 quarts, not 9.8 as you mentioned.
Old Jun 19, 2012 | 10:47 AM
FLDiscoII's Avatar
Thanks, Mike. I know a with a drain/refill you rarely get the "from dry" amount back in. But I thought the 19.7 pt that RAVE calls for was still pretty high.
Danan Coleman
Dec 14, 2013 05:31 AM
me 2
Apr 3, 2013 06:53 AM
Rover Chris
Mar 3, 2011 09:04 AM
Disco Alan
Apr 21, 2009 06:22 PM
tiredone
Mar 9, 2009 06:03 PM
