Transmission Fluid Leak
Old Nov 19, 2019 | 08:55 PM
Bart Mills's Avatar
6th Gear
Default Transmission Fluid Leak
Hello,
I've had a small transmission leak over the last few weeks that has become progressively worse. I have isolated the location and wondering if anyone has dealt with any leaks in these areas - Inspection cover on the torque converter and gearbox ( I will attach a picture) Thanks in advance.
Cheers, Bart
- Inspection cover and gasket leak - Gear Box Leak
Old Nov 19, 2019 | 10:06 PM
Best4x4's Avatar
I'd say the seal behind the torque converter.
Old Nov 19, 2019 | 10:09 PM
redwhitekat's Avatar
White shepherd / blue devil stop leak
or get it fixed with new seals etc
Old Nov 20, 2019 | 10:26 AM
Bart Mills's Avatar
6th Gear
That's what I suspected! I'll give the sealant a try and go from there. Thanks for the help.
Cheers,
Bart
Old Nov 20, 2019 | 11:10 AM
Sixpack577's Avatar
Are you sure it's transmission fluid?
Not engine oil? Rear main seal, or intake manifold leaking out the back and running down.
Old Nov 20, 2019 | 12:46 PM
Richard Gallant's Avatar
@Sixpack577 Looks like transmission fluid to me.
Old Nov 20, 2019 | 02:18 PM
Sixpack577's Avatar
I'm colorblind(really), so I had to ask.
If it were leaking on my truck, I could tell by texture and smell, even color...just not from a picture.
Oil drips from the same spot too.
Old Nov 20, 2019 | 02:48 PM
@Sixpack577 It sure does as I found out when my rear main started to leak and because I can not drop a transmission it cost a lot too.
Colorblind must make electrical work "interesting" sorry if I offended
Old Nov 20, 2019 | 03:02 PM
Sixpack577's Avatar
Ha! offended...no sir, not I, it's Hard to hurt my feelings, but thanks.
And yes, electrical is"fun". I try to go pin to pin on diagrams and take color out of it all together, but have been suprised several times over the years when the wrong color is in the wrong location, and from the factory.
I always have a friend work on that stuff with me to make sure I'm right.
I've learned not to trust just the color or the diagram, but to try and verify both.
drowssap
Jan 24, 2012 05:19 PM
Wildrider
Mar 6, 2011 06:43 AM
buick215
Dec 20, 2010 04:24 PM
bantham1
Oct 20, 2010 08:41 AM
bantham1
Oct 2, 2010 10:05 PM
