Transmission oil cooler, water pump, and head gasket leak
Thanks I will try to find those drain plugs today. If I can't find or remove them is there any other ways to get the extra coolant out?
I am also having some difficulty with the SAI and remove the large Union nuts that are at the bottom of the head connection. Any tips?
I found the Driver side coolant drain today and also drained from the water pump bolt. Was unable to locate the passenger side drain. Is it ok not to drain that side?
I also got all of the SAI removed and out of the way.
I also was following the rave and got to a point to remove the fuel rail line below the coil pack. I removed it and placed a rag under it and a few minutes later I smell gas and the rag is soaked and it's leaking gas everywhere. From what I read it sounds like it should have just spilled a little out and then stopped. I reconnected the fuel line to stop it.
Any advice regarding this?
Releasing the gas cap will remove some of the pressure, but you will have some leaking, but it will stop. If you are worried about emptying your gas tank, that won't happen.
Manual says to remove and discard, then replace with new. Just read a thread on another site and loose ones are preventing SAI manifold removal. Haven't read of others replacing them and not included in ABs kit? If replacements are available mine will be new going back together.
outdoor7or24
12-22-2014 09:31 PM
bcolins
08-13-2013 06:41 PM
