Transmission removal and install; any write ups or tips?
Old Apr 26, 2024 | 06:22 PM
Broken08's Avatar
Default Transmission removal and install; any write ups or tips?
I've searched a couple hours now and found exactly one poorly made video, (but still helpful) and nothing else on how to remove and reinstall a transmission.
mine lost forward so I have a low mileage one to install in it's place.
What else should I do when I'm there? Is the rear main easy? Transfer case?
Anything you have helps. Thanks
Old Apr 26, 2024 | 07:34 PM
Best4x4's Avatar
Remove both F/R Drive Shafts
Remove E Brake Assembly
Disconnect all TC wiring/linkages/vent line
Disconnect AT shifter linkage/wiring/vent line
Remove frame support under cats
Support TC
Remove TC support
disconnect O2 sensors
Remove Y pipe assembly
remove round plate on TC back (easier to drop TC) then remove gearset.
​​​​​​loosen TC Bolts to AT (front/rear of TC)
Remove TC mount
Drop TC
Remove Trans lines from TC
Loosen Torque Converter bolts (spin crank by hand and get to them above starter).
Loosen bell housing bolts
Drop TC
Basic instructions but ya get the idea
Old Apr 27, 2024 | 06:47 PM
Broken08's Avatar
Support TC
Remove TC support
Remove TC mount
Drop TC
Drop TC
That actually does really help. Thanks!
Anything about alignment on resemby?
Old Apr 27, 2024 | 07:15 PM
Extinct's Avatar
Make absolutely sure you seat the torque convert properly before install. Measure the depth per the manual. I would recommend replacing the tcase center shaft o-ring seal while you have it out. Good videos on how to to do it, bascially loosens the nut but do not remove. Tap shaft out far enough to remove o-ring and replace. Coat the head of the shaft with Permatex Hi-torque sealant. Reinstall and replace o-ring on nut end. Tighten nut one eighth turn additional, re-stake the nut. If your transmission is used you might want to consider replacing the front seal on the transmission. When you have the transmission out check the rear camshaft plug for leakage. You can email me and I will provide transmission manuals.
Old Apr 28, 2024 | 07:09 AM
Broken08's Avatar
Your profile doesn't get private messages.
Altitude7200@gmail dot com is mine
Thanks, great tips!
Old Apr 28, 2024 | 09:24 AM
Best4x4's Avatar
The transmission/engine have dowel pins that will properly seat them together when aligned and stabbed properly.
Old Apr 28, 2024 | 05:26 PM
Extinct's Avatar
Thanks, great tips!
Two email addresses in my sig
Jefro521
Jul 18, 2023 09:15 AM
threedeer
Dec 6, 2017 04:01 AM
dansgt
Feb 7, 2012 08:18 PM
