Transmission Replacement
Old Sep 28, 2023 | 01:49 PM
tim.mize's Avatar
5th Gear
Default Transmission Replacement
Hello everybody. I have a quick question. I own a 2002 Disco 2 and my trans is out, only have reverse. I came across a good deal on a 2004 trans, and it comes with the lockable diff. Will the 2004 model fit in my 2002? I have the Tom Woods driveshaft because I installed a 3 inch lift? And one more, what thermostat kit do I need to replace that factory set up? I just want a simple inline. Thanks
Old Sep 28, 2023 | 06:25 PM
mollusc's Avatar
Inline thermostat info is in a sticky thread at the top of the D2 forum.
I can't answer the question about whether it will fit but I do think the later transmission is slightly longer. You might need the transmission and transfer case mounts along with the tranny and t-case themselves.
If you get the 2004 transmission/transfer case setup, you will also need a mechanism to activate it. I have a complete assembly out of a Disco 1 that's ready to go into another D2; it will be for sale very soon. If you are interested please send me a DM.
Old Sep 28, 2023 | 07:05 PM
Extinct's Avatar
There is a small driveshaft length difference, do a search, you should find enough information.
Old Sep 29, 2023 | 02:48 AM
miron's Avatar
2004 trans is 5/8" longer than 2002.
Old Sep 29, 2023 | 09:14 AM
tim.mize's Avatar
5th Gear
I’ve looked online, I can’t find an answer if it will fit or not. I did find where it is longer, but I was wondering if anyone could tell me if it would fit or not. Thanks
Old Sep 29, 2023 | 09:17 AM
tim.mize's Avatar
5th Gear
@mollusc very interested in the shifter plate if this trans will work in my Disco
Old Sep 29, 2023 | 10:28 AM
mollusc's Avatar
The transmission and transfer case mounting blocks will be slightly different, but will attach to the same points on the chassis regardless of what year you have. So you MAY need to get those blocks as well, as I said. Or you may not need to at all. Or you may just need to elongate the holes in the mounts that are already on your truck.
Old Sep 29, 2023 | 10:33 AM
tim.mize's Avatar
5th Gear
Thanks for the info brother.
Old Sep 29, 2023 | 01:12 PM
miron's Avatar
Just a little follow-up - I was actually replacing my TC and refreshing the transmission. I was recommended to upgrade to the HP24, but after doing some research it looks like the 24 was some kind of one-off upgrade for LR and as little difference, as there is between 22 and 24 I was having a hard time finding replacement parts that would specifically say they will also fit the 24 (I'm not a transmission specialist so if it doesn't say on the box it will fit, I don't risk buying ). On the other hand, HP22 was installed in a bunch of other cars and parts are plentiful (I was actually using a rebuild manual for a Renault). It probably doesn't really matter since these transmissions are supposed to run for a long time, but if you have plans to rebuild your "new" one, might be worth considering.
Brandon318
Sep 23, 2020 07:33 PM
04duxlr
Jun 30, 2017 12:01 PM
wabbott82@gmail .com
May 31, 2014 03:09 PM
Jared Klatt
Jun 29, 2012 06:26 AM
spw0440
May 29, 2011 07:23 PM
