Transmission Rubber Plugs
Old Dec 28, 2008 | 02:19 PM
black bear's Avatar
5th Gear
Default Transmission Rubber Plugs
While rebuilding my driveshaft I decided to clean up the under carriage to determine the source of a few leaks. I noticed two rubber plugs on each side of the transmission just above the driveshaft. Both were partially unplugged. I was able to easily press one back into place, however the larger one is difficult. Is this where tranny fluid is added? I do not seem to have a transmission dipstick. How can I check the tranny fluid?
2000 DII, 122,000 miles
Old Dec 28, 2008 | 02:29 PM
Default RE: Transmission Rubber Plugs
You fill and check your fluid thur the metal plug in the side of your tranny pan, only when the engine is warm, running and in park.
Old Dec 28, 2008 | 02:31 PM
By the way, did you order and install a new centering ball kit while doing the rebuild, if not the shaft will fail again very quickly.
oilspotLR
Oct 30, 2015 03:47 PM
peterh
Feb 9, 2015 07:45 AM
Jared9220
Sep 25, 2012 08:45 AM
renfield
Aug 2, 2011 02:59 PM
RegT
Jan 17, 2011 07:37 PM
