Transmission Temp Warning ON?
Old Jun 26, 2019 | 02:19 PM
Joelewis73's Avatar
5th Gear
Default Transmission Temp Warning ON?
Need a little assistance please. The transmission warning light is on and does not go off. I will simply start it up cold and the light will go out. Can someone point me in the direction to purchase a new sensor. Found them on AB but not sure which one I need. Pretty sure I will get some off topic responses but oh well it happens. 2002 Disco II LSE
Thanks
Joe
Old Jun 26, 2019 | 05:53 PM
Motorhead1's Avatar
Unplug the sensor on the lower right hand side of the radiator and see if the light stays out, if everything stays the same, plug it back in and then unplug the temp sensor on the transfer case.
Old Jun 26, 2019 | 06:27 PM
Extinct's Avatar
That trouble light actually has two sensors connected, one in the transmission cooler and one in the transfer case. Transmission cooler plug is under the top radiator shroud on the passenger side. You can unplug it there and check it, if it is not the bad one then the transfer case one is probably the issue. Mine was the trans cooler. Download the rave and read the functional description on the sensor and look at the circuit diagram so you can understand it.
Old Sep 10, 2019 | 07:58 PM
DoubleAFL's Avatar
I've got to do this same thing - mine goes in and out non-stop.
good info, thanks!
Aaron
andrewd
Jul 19, 2016 09:54 AM
Kayode Oyenuga
Dec 27, 2014 03:45 PM
dusty1
Jul 8, 2014 05:00 PM
Fishman
May 19, 2014 06:10 AM
Rover789
Jun 1, 2009 06:30 AM
