Transmission Won't Engage w/o E-brake
Old Aug 31, 2020 | 03:16 PM
Jason Spelts's Avatar
Originally Posted by Alex_M
If it will only run when the park brake is engaged then your rear end let go. Most likely the spider gears in the rear diff, possibly the ring and pinion, maybe even an axle. My money is on the spider gears. With the park brake engaged it is allowing you to drive on the front end.
This would be a 3 or 4 hour job to fix simply by removing the rear 3rd member and dropping a new one in out of a junk yard truck.
It'd be great if I wasn't 1,000 miles away from both home and tools. Right now the truck is parked in a residential area near downtown Houston.
As I have no other transportation (and I do not know a soul in the area), I'm kinda screwed.
Old Aug 31, 2020 | 03:19 PM
Also, the banging and clanging noise under the shifter kinda makes me think the rear end is OK. But in all honesty I know jack squat about this
Ivan0z
Apr 18, 2020 08:53 AM
riggskwong41
Dec 4, 2014 10:59 PM
blackshadow305
Apr 9, 2012 10:26 PM
u1297
Jul 15, 2009 09:10 AM
herzzreh
Dec 9, 2006 11:39 AM
