Transmisson noise
Old Sep 2, 2008 | 02:40 PM
redhawk's Avatar
6th Gear
Default Transmisson noise
My 04' Disco has 102K miles on it. It is making a knocking noise when I take off, which I believe is coming from the transmission. In fact there is a bit of a vibration at about 45mph. Sounds like a muffled water pump going bad or a throw out bearing. The transmission seems a bit strained when shifting also. Anyone have a clue?
Old Sep 2, 2008 | 02:49 PM
Default RE: Transmisson noise
STOP DRIVING THE TRUCK!!!!!! It sounds like yoiur double cardon joint is about to fail, when it does it is a $7,000 fix, no joke dude, have it flatbeded to a driveline shop. Dont even put it in gear!!! Dont start it, nothing!! Get your stuff out of it and call a tow truck!!!!
I AM NOT JOKING AROUND ON THIS ONE!
Old Sep 2, 2008 | 02:52 PM
Check your drive shafts first, how often do you lube them and have you replaced the 2 bad front u-joints?
Have you geted your diffs and t/case for fluid, when were they last serviced?
Noise is most likely not the tranny, try driving with the t/case in low range, any difference?
Don't drive it till you can get it to your mechanic!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 2, 2008 | 03:21 PM
redhawk's Avatar
6th Gear
Thanks Guys. Disco Mike I read some of your other posts on this subject. I think you are absolutely right. Will shut it down and get it hauled to a mechanic ASAP! Thank you again, Redhawk
mvjimenez
Jun 17, 2014 12:28 PM
30more
May 28, 2012 05:01 PM
zoomzoom
Feb 1, 2011 07:05 PM
adrianwood
Freelander
Jun 13, 2005 08:53 PM
