trany oil change
then check it while it it is running in park.So you don't burn your self first of all and so when you go to do the second refill the tranny will be warm on after you start it up and switch back and forth from reverse to drive twice
thanks Mike, after, the first refill, should I drive it a few yard forward and reverse or I just stay put and changing the gear to forward and reverse before the 2nd fill ?
long time I haven't spoke to you, how is everything ?
collin Barrows
Aug 28, 2011 07:13 AM
