Tricky Dick - Ticking From Pulley
Old Dec 17, 2017 | 11:41 AM
Friday Night Disco's Avatar
Default Tricky Dick - Ticking From Pulley
So I noticed a ticking sound that increased in frequency as RPMs increased.
I did some poking around and I can feel the ticks on the pulley mount below the alternator.
I did check the valve cover and exhaust manifold but, couldn't feel the ticks there. Only on the pulley mount and a slight amount on the alternator.
Questions are:
Is this as simple and replacing the pulley or is this a sign of something else?
Has this happen to others?
Old Dec 17, 2017 | 02:33 PM
number9's Avatar
Have you removed your belt yet and rotated each pulley by hand yet? Majority of the pulleys/idllers have replacable bearings, alt and H2O/hyd pump(s) are solidly attached to their shaft. Your tick could be from alt bearings.
Old Dec 17, 2017 | 03:10 PM
i have not rotated by hand yet, that will be my next step once I wrap up my other project
Old Dec 18, 2017 | 10:58 AM
Update...
While wrapping up another project (removal of heating plate/ exhaust leak) I noticed that the serpentine belt had a large chunk missing. I just replaced the old with this new one about 1,000 miles ago. Luckily I saved the old one.
Next steps...
Remove bad belt
Check each pulley for any wobble or resistance
Old Dec 18, 2017 | 05:05 PM
Update...
It was the serpentine belt (see below)
I also checked each pulley and no play easy to move forward and backwards. For good measure I hit all the pulleys with a scot brite pad.
Tick is gone, just need to order a new serpentine belt, odd how the new went bad so quick
Last edited by Friday Night Disco; Dec 18, 2017 at 05:07 PM. Reason: momma said knock you out
Old Dec 18, 2017 | 05:07 PM
Old Dec 18, 2017 | 05:20 PM
mln01's Avatar
What brand was the belt? I had a Goodyear Gatorback/Conti Elite belt fail catastrophically after ~7,500 miles.
Old Dec 18, 2017 | 05:28 PM
AllMakes 4x4 from Amazon
Amazon Amazon
Old Dec 18, 2017 | 06:31 PM
OverRover's Avatar
WOW shocking another fine piece of from ALLMAKES! And +1 Avoid the Goodyear/Conti belts.
PLEASE get a GATES Belt and get back to HAPPY TOWN.
You either need a #K017065 if your truck has AC and ACE
OR #K070922 if you have AC and No ACE. You can get them online or any NAPA sells Gates Belts.
Old Dec 18, 2017 | 09:11 PM
Going to order Land Rover brand from Amazon. Thanks for the feedback
Friday Night Disco
Aug 4, 2021 03:12 PM
Friday Night Disco
Mar 27, 2017 06:39 PM
Friday Night Disco
Feb 4, 2017 06:05 PM
Friday Night Disco
Jan 21, 2017 08:31 PM
Friday Night Disco
Jan 18, 2017 09:53 AM
