trouble with ABS kicking in at 60 mph
Old Aug 4, 2015 | 06:29 AM
thegamefisher's Avatar
3rd Gear
Default trouble with ABS kicking in at 60 mph
so I had my front near side bearing and all in one abs sensor changed, as it register worn.
after the work was done the ABS comes on if you brake between 60 to 65 mph
its fine at all other speeds, also the traction control comes on at the slightest thing, its all to do with the off side wheel.
we change the drivers side bearing as well, but still hasn't cured it.
any ideas please. my mechanic said he is having trouble as the diagnostic tester doesn't work at 60 mph.
Old Aug 4, 2015 | 07:26 AM
If your mechanic doesn't have a Rover specific ABS capable scanner, you are just throwing money away. How many miles on the truck?
What you are describing sounds like the hub assembly was not installed correctly and actual codes need to be found so you fix it right.
Old Aug 4, 2015 | 08:25 AM
Externet's Avatar
The speed sensor emits a continuous sinewave related to the wheel speed. Loss of that signal will be interpreted by the compfuser as skidding on ice or wheel lifted from ground, or stopped
For the ABS to engage a wheel, is because sensed a wheel stopped.
I venture to say there is a bad connection from a sender in that axle. Check recessed pins in a connector, contacts corrosion.
Old Aug 4, 2015 | 08:55 AM
3rd Gear
Many thanks for this, mines an 04 d 22 with 80,000 on the clock. its also have the TC go off on the off side at slow speed, sounds like i need to find some one different to have a look.
many thanks
Old Aug 4, 2015 | 08:56 AM
3rd Gear
many thanks for this, ill let him know. it would be the cheapest thing to looks at first
dirtbag
Jun 3, 2015 07:51 AM
bcameron70
Dec 3, 2011 08:27 PM
hsipromo
Jan 17, 2010 09:19 PM
TexasLR3
Sep 24, 2007 12:03 PM
