Trouble Code help
Old Dec 8, 2008 | 03:07 PM
AK Rover's Avatar
Default Trouble Code help
I decided to plug in my code reader and see what is causing my check engine light to stay on. I have the codes, looked up the meaning and now need some help translating the meaning to real world.
P0158 - Oxygen Sensor High Voltage Fault
P1193 - Oxygen Sensor Heater Circuit Open Downstream
Both of those are obviously O2 sensors, probably bad but going to make sure one isn't just unplugged.
P1447 - Evap System Purge Valve Open or Short
P0451 - Fuel Tank Pressure Sensor Signal Error
Any help where to start to fix these problems is appreciated.
Old Dec 8, 2008 | 06:17 PM
Default RE: Trouble Code help
When was the last time you had a tune up?
The first signs of needing a tune up are the O2 codes, then mis-fire codes.
Check and make sure that you gas cap is tight.
Old Dec 9, 2008 | 10:11 AM
AK,
How many miles on your truck? Are these the original 02's?
Old Dec 9, 2008 | 05:30 PM
AK Rover's Avatar
I have 111000 miles on the truck. I don't know if they are the original O2's. I climbed under the truck yesterday after clearing the codes and found that the passenger side rear O2 was plugged in but not fully locked into the connector. I pushed on it and heard it lock into the connector. Since I was pretty much working my brail and couldn't see the plug I am guessing it only moved about 1/4 inch before it locked in place. The rest of the connections were solid in their plugs. Since pushing that plug in the check engine light has not come back on despite multiple times starting and stopping the truck.
Old Dec 9, 2008 | 05:40 PM
Lets hope it was as simple as that, a loose O2 connection.
Old Dec 9, 2008 | 06:25 PM
AK Rover's Avatar
I tend to be a realist so I'm not putting a lot of faith in that being the only problem but sometimes even I get lucky. The open sensor heater circuit downstream code gave me the idea to check the connections and I found that the loose connection was in the downstream (after cat) sensor. I'll let you know if the CEL comes on again.
Matt_Attack352
Jan 13, 2014 09:55 AM
saltyrover
Apr 25, 2013 06:44 PM
sayeedA
Nov 15, 2011 11:02 PM
shearer60
Nov 13, 2007 07:47 AM
dc10freighter
Aug 29, 2007 09:17 AM
