Trouble starting
Old Jun 19, 2012 | 06:03 PM
stonecold's Avatar
Default Trouble starting
My wife has a 02 disco and it is hard to start at times. Some days it starts on the first crank and then it may take three attempts to start it. It has 135,*** on it and runs perfect other than the cranking issue. Before I let her take it to the dealer to take all my money I thought I would ask here first for suggestions as to what might be causing this propblem. Anyone?
Old Jun 20, 2012 | 05:12 AM
CKP (crank position sensor) starting to fail? More often does this when engine hot also. You can buy a spark tester for under $10 that you touch to a plug wire to see if there is spark. If no spark, usually the CKP. Could also be fuel pump/filter related, they are all in the tank together. testing fuel pressure is not so easy, test port is under back driver corner (NAS) of top intake manifold.
Matt_Attack352
Jan 13, 2014 09:55 AM
socrazy2992
Jul 14, 2012 05:12 AM
hateroffreelander
Aug 23, 2009 11:34 AM
sdsilvere38
Feb 3, 2009 05:35 PM
smt
Mar 1, 2008 11:44 PM
