Truck won't start after Heater Core and Head Gasket replacement
Old 07-06-2012, 04:36 PM
Bkreutz's Avatar
IIRC that is the ground for the injector harness (could be wrong though, that's what comes to mind) It's one of those wires the factory puts on before the body is installed so it's a pain to install, I used to relocate that ground to a bolt on the top rear of the engine, I think one of the bolts that holds the fuel rail to the intake.
  #32
Old 07-06-2012, 04:43 PM
DiscoRover007's Avatar
Would this likely be the culprit then? If it is confirmed to be a ground? I dont remember taking it off but I did pull on the harness a time or two.
  #33
Old 07-06-2012, 04:59 PM
Bkreutz's Avatar
Won't know until you try. This is the problem with "long distance" diagnosis, when I'm looking at a vehicle in person there are a lot of things I check without thinking (force of habit) that don't get passed on over the internet. I just remember the PITA wires at the back of the engine when I did head gaskets (a very frequent occurrence at the dealer)
  #34
Old 07-06-2012, 05:16 PM
jfall's Avatar
On the USA Discovery II on the Driver' side.
Or the right side when looking into the engine compartment with the hood/bonnet propped up..
On the rear of the driver's cylinder head
is a braided wire.
Connects from the head to the fire wall.
Please assure said wire is in place.
I strongly doubt that will make any difference at all.
Please check:
MAF plug
Throttle position plug
Also -
If you did not number your spark plug wires as 1,2,3,4,5,6,7,8
how did / can you assure you are on the correct spark plug?
I am betting you have two cylinders switched on each side and you are only running on 4 cylinders.
Don't try to pull the wires off the plugs with the engine running unless in
your younger years you had an affection for electric fences. You may get shocked again.
Plus you'll damage the ignition coils = perhaps.
You should have pending misfire codes.
Please pull the pending codes and fix the associated cylinders.
They start at #1 on the driver's side and alternate side to side and to the back.
I doubt you have the coil plugs swapped. It would probably not fire at all.
  #35
Old 07-06-2012, 07:01 PM
I checked the spark plug wiring and all was correct. I made sure the throttle plug and maf was secured as well. Looks like i wont be putting her back together and trying to start her till tomorrow.
simply be a case of pinched wiring.
  #36
Old 07-08-2012, 01:39 AM
Alright so my mechanic buddy came over today. Overall we are still unsure of whats going on with the truck, it does not idle still and dies out.
However we started the truck and we started pulling spark plugs. Surprisingly the truck sounded much more normal, almost as if it was idling with plug wire 8 disconnected. The truck would still die out but when given gas it was close to sounding normal. Some wires had more spark than others when he was pulling them. When all wires were plugged up it sounded like ****. The truck finally threw a code today but we are unsure if that it just from pulling the wires or if it is something else. We'll have it scanned tomorrow.
Thoughts? best guess? Damaged spark plug wires?
  #37
Old 07-08-2012, 09:43 AM
Are there any eletrical plugs under the dash that could be having this effect?
  #38
Old 07-08-2012, 10:10 AM
Bkreutz's Avatar
Pulling the plug wires could give you misfire codes but that would depend on how long you left them off and if you shut the engine off, restarted it and did it again. (that would have certainly set a pending code but not necessarily turned the CEL on)
  #39
Old 07-08-2012, 02:58 PM
Okay got the code. P1300 which is for coil 1 malfunction... -ignition coil primary feed back circuit...
How often do coil packs go bad for the D2?
  #40
Old 07-08-2012, 04:05 PM
Okay, cleared the code and wouldn't come back after trying to start it a couple more times. Pulled the plugs on the drivers side head and several cylinders aren't firing. Think I might try new wires and see if we can test the coil pack.
Quick Reply: Truck won't start after Heater Core and Head Gasket replacement
