Trying to find a fuel pump replacement
Old Sep 14, 2016 | 12:58 PM
jackorr's Avatar
Default Trying to find a fuel pump replacement
My fuel pump pood out on me and I'm having a difficult time finding a fuel pump replacement() I really dont want to spend a ton of money on one but I absolutely need on asap. Can someone recommend one to me with links? I found a bosch one a little while back but i cant seem to find it anymore. I want to say it was like 165.00. any help is much appreciated.
EDIT: Okay im going to say its SAI because it does not have the black sensor plug on top of the pump.
Old Sep 14, 2016 | 02:51 PM
d.a.r.y.l's Avatar
Rockauto,com has them starting at $113.79. Need more info about your Rover befor final price can be determined. D*
Old Sep 14, 2016 | 03:44 PM
Best4x4's Avatar
Yep there is a difference between SAI & None SAI. I've never torn down a D2 fuel pump assembly but it sure was nice on the D1 to just slap in a Corvette fuel pump into the D1 assembly for 50.00. Would be great if a D2 was the same way!!
Old Sep 14, 2016 | 04:57 PM
shady milkman's Avatar
If your pump housing is still in tact, then go to auto zone and buy the airtex E8335...it is a direct replacement. Mine went out a few years back and I literally took the old one out of the housing and slid that one right in....easy peasy
Old Sep 15, 2016 | 12:17 PM
jackorr's Avatar
Ill give the airtex a try since its like 65 bucks at advanced auto. thanks
Old Sep 15, 2016 | 12:42 PM
OffroadFrance's Avatar
If you're stuck try on here as some guys break D2's and I'm sure they will have a used pump.
Paul Grant and Abran Abeyta are both D2 specialist breakers.
Old Sep 15, 2016 | 12:49 PM
zuke's Avatar
Default Ebay E8335 Airtex
I saw this pump on ebay with a new strainer for $29
Old Sep 15, 2016 | 05:27 PM
PalmettoDisco's Avatar
Checked on the $29 online , and there are some under $23! You can buy a spare for that cheap. If they only last a couple of years that's $1 per month. Access is easy once you get under the carpet, as I recall.
jhewitt1111
Jan 29, 2011 06:34 PM
Nighthawk15
Appearance & Camping Set Ups
Oct 7, 2009 11:01 AM
Disco2Fever
Jul 13, 2009 07:54 PM
Pauljd
Nov 26, 2008 08:23 AM
negativecapability
May 7, 2008 03:21 PM
