Trying to potentially fix damage to my D2.
Old Oct 27, 2021 | 08:55 PM
DiscoJay99's Avatar
4wd High
Default Trying to potentially fix damage to my D2.
The other day I was doing a bit of off-roading in my discovery and I ended up tipping into some trees due to a foolish mistake I made. I’m hoping to have it fixed due to how well I have this one running and the amount of mechanical work I’ve put into it recently. Not concerned with it being very pretty, that was never my goal, but something I can take on any road in the world. Looking to buy large roof basket so dents shouldn’t be super noticeable anyways.
Smashed glass and bends around fittings
A pillar is bent L driver door will not open/close properly
Old Oct 27, 2021 | 09:08 PM
gheorghe648's Avatar
Ouch, but the damage and amount of work might be more than it would be to find another and keep this as a parts car.
Old Oct 27, 2021 | 10:15 PM
04disco2va's Avatar
Hate seeing that happen! Any chance it doesn’t look quite as bad in person?
Old Oct 28, 2021 | 09:41 PM
nashvegas's Avatar
That stinks. That's the kind of damage that definitely totals a D2 on an insurance claim and is tough to fix yourself. I'd buy another one and swap every good part from yours over to it and keep a parts rig.
On the other hand... you could replace the drivers side mirror (easy), alpine light (not expensive really), and the windshield (may have an A pillar issue there) and not worry about cosmetics and be 100% fine.
Old Oct 29, 2021 | 08:40 AM
PickleRick's Avatar
X2 on body swap if you don't want it looking like a trail rig. Some like that look.
if you're a good welder/fab guy you could repair it however if you had the needed know how/equipment/tools you wouldn't be on here asking.
If you're in the south east I have access to a good clean white body. The better half's rig is the dark green color so the body is useless to me.
Old Oct 29, 2021 | 09:58 AM
tnrangerover's Avatar
I think the easiest thing to do is going to find a good example with a bad motor for cheap, and swap everything you like over. hold onto your current disco for parts. Otherwise, if you have the abilities, just cut the roof off, cage it, and have a soft top made for it. that's what most guys seem to do that wheel that hard, mistake or not.
If you're extremely handy, then you could buy a wrecked disco and cut the A-Pillars out, remove the roof (it's spot welded along the sunroof drains) and then weld in a new a pillars and roof. too bad the roof isn't bolted on like the RRC.
sorry to see it. hope you figure something out that works for you. I didn't think it was too bad until I saw the a pillar. I wouldn't trust that in another rollover or a highway accident with that crumpled metal. you might want an exo cage at least on the next one.
Old Oct 29, 2021 | 10:21 AM
whowa004's Avatar
I don't think I've seen a chopped d2, definitely seen a few d1s and classics. Looks like OP is in maine so that would be a cold ride the majority of the time lol
Old Oct 29, 2021 | 12:46 PM
there are a few around on disco web and a few on google. The rear door and taillights make it a little finicky unless you want really get into some metalwork.
there also a slick pickup truck fiberglass conversion from the UK that is like 800 pounds plus shipping. pretty neat conversion
Landy718
Apr 6, 2021 08:39 AM
bmwrovers
Mar 24, 2020 07:23 AM
greisinb
Nov 13, 2019 11:55 AM
alpinacsi
Build Threads
Dec 11, 2017 07:30 PM
projektD2
Build Threads
Jul 24, 2016 10:43 PM
