Trying to remove transfercase shift Knob
Old Jan 7, 2010 | 08:39 PM
Willie00d2's Avatar
Default Trying to remove transfercase shift ****
I am Trying to remove the transfercase shift **** so I can put a new leather boot on it. Is there a trick to getting it off? It rotates on the shaft but will not pull off.
Thank you,
Willie
2000 Discovery II
Old Jan 7, 2010 | 08:45 PM
Camdisco24's Avatar
You have to pull really hard, and I mean you gotta use everything you got.
Took me a while to get mine off, but it will eventually.
Old Jan 7, 2010 | 08:58 PM
lipadj46's Avatar
+1 just pull harder
Old Jan 7, 2010 | 10:40 PM
humroot's Avatar
If you mean the HIGH / LOW shifter (transfer case) it unscrews. The TRANMISSION selector **** pulls off.
Old Jan 7, 2010 | 11:00 PM
discoxd's Avatar
yeah t-case *** unscrews... just keep turning it...
Old Jan 8, 2010 | 06:17 AM
03discoman's Avatar
discoxd was the winner of this topic... the tranny shifter pulls off while the t caSE spins off......DISCOXD FTW!!!!!!!!!!!!!!!!!!!
Old Jan 8, 2010 | 11:11 AM
Camdisco24's Avatar
Actually Humroot wins if we're picking thread winners now.
To the OP, mine did not come off with spinning so I had to pull. If you cant get it to spin off, you may have to pull it.
Old Jan 8, 2010 | 11:40 AM
hilltoppersx's Avatar
unscrew as fast as you can and pull as hard as you can. one will eventually work.
Old Jan 8, 2010 | 12:09 PM
Willie00d2's Avatar
I unscrewed the hi-low ****. For some reason I thought it pulled off too. The new leather went on easy. I used 3M high performance contact adhesive, works good on leather.
This is the boot set I used.
http://cgi.ebay.com/ebaymotors/LANDR...item3a54cdf877
Willie
Old Jan 8, 2010 | 12:16 PM
Camdisco24's Avatar
Very nice! Glad you got it off!
Motorhead1
Dec 26, 2019 10:55 AM
Brokenrover
May 27, 2017 12:34 PM
corbinwelter
Dec 28, 2014 04:19 PM
Willie 00D2
Jan 3, 2009 11:37 PM
fri3daz3
Aug 18, 2008 09:24 PM
