Turning knock
Old Feb 23, 2011 | 05:58 PM
indy11bravo's Avatar
Default Turning knock
I have an 03se with 88k on it. Whenever I make a slight left hand turn, I get a rotational knock in what feel like right under my feet. It is pronounced enough that if I didn’t know better I would think something was physically striking under my feet. It only seems to be at lower speeds, only on left turns (think enough for a roundabout, not enough for a 90 degree). When making sharp turns it is not present. I do not have any vibration in the wheel, my alignment is good… Anybody have any idea what could be causing the noise?
I don’t have the ability to work on it myself at the moment, so it is going in the shop next week for this and to also have my front driveshaft rebuilt. I’m just trying to get an idea of what it could be, and if I should be driving it as is.
I appreciate the insight.
Old Feb 23, 2011 | 06:43 PM
David A's Avatar
I dont know what it is but since you have a stock DS I would not drive it.
Old Feb 23, 2011 | 08:46 PM
lordmorpheus's Avatar
If it only happens when turning one direction, and not the other, I would be thinking C/V joint.
Regardless, if your front drive shaft isn't rebuilt, get it done.
Ezio04Rover
Nov 22, 2013 09:32 PM
Ezio04Rover
Nov 22, 2013 08:43 PM
tibyABv6
May 16, 2010 11:35 PM
targotsi
Feb 18, 2009 05:58 PM
stick
Jan 27, 2008 01:29 PM
