turning over
You wont need the code unless you disconnect the battery. You can charge it with it still hooked up to the trk.
To enter the code you need to turn the key on, the stereo will say "CODE" and then you enter it into the stereo. Then it will work. No code, no worky worky.
lol okay. i think ill try charging the battery because that was my first guess on why its not turning over right away but will post if it worked later today if i get to doing it.
After you charge it you can take it to AutoZone and they can test your battery and alternator for you.
If your alternator isint putting out enough your battery will go dead. If your battery is old/weak then your alternator will work to hard and burn its self up trying to power enverything.
Lots of short trips with a high AMP load will run a battery down. For example...you have the lights on, the A/C and rear defroster all on at the same time and you only drivemile and then turn it off. Repeat this several times and the alternator doesnt get to charge the battery long enough to charge the battery fully.
So charge your battery with the battery charger, have the battery and alternator tested and then go from there. Change your driving habits if you need to.
ImQuattro
Apr 4, 2014 05:58 AM
SolbergFanBoi
Mar 5, 2012 07:05 PM
RoverinATL
Jul 2, 2010 05:58 AM
